1375
Doubt regarding manual paging.
Hello everyone,
So, i want to perform manual paging where i bring data in pages only when user change the page number. I m unable to perform this. Please help me out with this.
note : In below code i have not enabled manual paging as i m confused how to extract parameter from query string and how to bring data only when user switch pages.(server side paging)
Code:
@using Infragistics.Web.Mvc;
@using System.Text.Json
@*@model IEnumerable<GridTransaction.Models.Student>*@
@* The Ignite UI for MVC Grid data source uses LINQ and therefore only accepts instances of IQueryable<T>.
Even when you opt to use the GridMode you will explicitly set the DataSource property which
requires an instance of IQueryable<T> .*@
<html>
<head>
</head>
<body>
Html.Infragistics().Grid(Model).ID("grid").PrimaryKey("Id").AutoGenerateColumns(false).Width("100%").AutoCommit(false)
.Columns(columns =>
columns.For(model => model.Id).DataType("number").HeaderText("Student ID").Width("15%");
columns.For(model => model.Name).DataType("string").HeaderText("Student Name").Width("30%");
columns.For(model => model.Marks).DataType("number").HeaderText("Marks").Width("30%");
columns.For(model => model.subject).DataType("string").HeaderText("Subject").Width("15%");
columns.For(model => model.Imagepath).DataType("string").HeaderText("Imagepath").Template("<img src='${Imagepath}' width='50' height='50' />");
}).DataSource(Model)
// Set the data source URL
.Features(features =>
features.Selection().MultipleSelection(true);
features.GroupBy();
features.Paging().PageSize(10);
features.Updating();
features.Tooltips().Visibility(TooltipsVisibility.Always);// provide informaion about grid when you hover over
features.RowSelectors().EnableCheckBoxes(true);
features.RowSelectors().EnableRowNumbering(true);
features.Updating().EnableAddRow(true).EnableDeleteRow(true);
features.Sorting().Type(OpType.Remote).SortUrlKey("hi");
features.Updating().ColumnSettings(set =>
set.ColumnSetting().ColumnKey("Id").ReadOnly(true);
features.Filtering();
}).UpdateUrl(Url.Action("put"))
.ResponseContentType("Json")
.DataBind()
.Render()
<div>
<table id="grid">
</table>
</div>
<div class="text-center">
<button id="savechanges" class="btn btn-primary">Save</button>
</div>
</body>
</html>
@section scripts{
@*Batch Update*@
<script>
$(function () {
$("#grid").igGrid({
primaryKey: "id",
renderCheckboxes: true,
autoGenerateColumns: false,
updateUrl: "/Student/put/",
width: "100%",
columns: [
{ headerText: "Student ID", key: "id", dataType: "number", width: "15%" },
{ headerText: "Student Name", key: "name", dataType: "string", width: "30%" },
{ headerText: "Marks", key: "marks", dataType: "number", width: "30%" },
headerText: "Image",
key: "imagepath",
dataType: "string",
width: "15%",
template: "<img src='${imagepath}' width='50' height='50' />"
{ headerText: "Subject", key: "subject", dataType: "string", width: "15%" }
dataSourceUrl: "/Student/Data12",
dataSource: "/Student/Data",
features: [
mode: "row",
multipleSelection: true
enableCheckBoxes: true,
enableRowNumbering: true
type:"local",
pageSize : 7
type:"remote",
filterExprUrlKey: "filter",
columnSettings: [
columnKey: "selectColumn",
allowFiltering: false
type: "remote",
// sortUrlKey: 'sort',
// sortUrlKeyAscValue: 'asc',
// sortUrlKeyDescValue: 'desc'
enableAddRow: true,
editMode: "row",
validation: true,
enableDeleteRow: true,
rowAdded: function (evt, ui) {
// Custom logic to execute when a row is added
console.log("Event arguments (ui):", ui);
console.log("Row data:", ui.rowId);
console.log(typeof (ui.values));
columnSettings: [
columnKey: "id",
readOnly: true
columnKey: "name",
editorType: "text",
validation: true,
editorOptions: {
validatorOptions:
required: {
errorMessage: "You must enter a value to submit."
custom: function(ui,evt){
var validator = $("#grid").igGridUpdating("editorForKey", "name").data("igValidator").element;
console.log(validator);
if (ui == "rohit") {
$(validator).igValidator("option", "errorMessage", "cant enter name rohit");
return false;
return true;
columnKey: "marks",
editorType: "number",
validation: true,
editorOptions: {
validatorOptions: {
required: {
errorMessage: "You must enter a value to submittt."
custom:function(ui,evt){
console.log(ui);
console.log("hi");
if (ui >= 50) {
var validator1 = $("#grid").igGridUpdating("editorForKey", "imagepath").data("igValidator").element;
// var validator11 = $("#grid").igGridUpdating("editorForKey", "imagepath");
// console.log(validator11);
// console.log("hi");
// var validator12 = $("#grid").igGridUpdating("editorForKey", "imagepath").data("igValidator");
// console.log(validator12);
//Set
$(validator1).igValidator("option", "required", true);
$(validator1).igValidator("option", "errorMessage", 'This field is required for marks between 50-100');
return true;
else {
//Set
$(validator1).igValidator("option", "required", false);
return true;
$("#savechanges").on("click", function () {
alert("Save button clicked");
// Save changes when the button is clicked
$("#grid").igGrid("saveChanges");
</script>
ASP CODE  TO HANDLE PAGING:
public JsonResult Data12()
var absolutepath1 = HttpContext.Request.QueryString.ToString();
var absolutepath = HttpContext.Request.Query["$orderby"].ToString();
Console.WriteLine(absolutepath1);
string[] m = absolutepath.Split(' ');
//foreach(var m2 in m)
// Console.WriteLine(m2);
// absolutepath.Remove("?");
var colname = m[0];
var orderb1y = m[1];
IEnumerable<Student> sat = data.sort(colname, orderb1y);
// IEnumerable<Student> students = data.GetStudents();
return Json(sat);
