I have implemented an ig Grid in my application where I am trying to fix the columns of grid at both the ends. But I am not able to do this. It allows me to fix column at right or left side but not both the sides. Is there any way to fix the column at both sides. Below is the line of code I am already using:
$("#grid").igGrid({ primaryKey: "colId", autofitLastColumn: false, autoGenerateColumns: false, dataSource: dataSource, responseDataKey: "results", columns: [ { headerText: "Column One", key: "colOne", dataType: "string", width: "140px" }, { headerText: "Column Two", key: "colTwo", dataType: "string", width: "140px" }, { headerText: "Column Three", key: "colThree", dataType: "string", width: "140px" }, { headerText: "Column Four", key: "colFour", dataType: "string", width: "140px" }, { headerText: "Column Five", key: "colFive", dataType: "string", width: "140px" }, { headerText: "Column Six", key: "colSix", dataType: "string", width: "140px" }, ..... ...... ...... ...... { headerText: "Column Eleven", key: "colEleven", dataType: "string", width: "140px" }], features: [ { name: "ColumnFixing", fixingDirection: "left", // I want Both right and left columns to be fixed columnSettings: [ { columnKey: "colOne", isFixed: true, allowFixing: false }, { columnKey: "colTwo", isFixed: true, allowFixing: false } ] }, { name: "Sorting", type: "local", }, { name: "Filtering", type: "local", }, { name: "Paging", type: "local", pageSize: 5 } ] });
This gives me expected grid with all data, but only one side column can be fixed not both sides. My requirement is to fix columns both side.
Please help me in this regard.
Thank you in advance.
Hello Sai,
igGrid Column Fixing doesn't support fixing columns on both sides of the grid.
You can suggest this functionality as a new product idea for future versions at <http://ideas.infragistics.com>.
There are many benefits to submitting a product idea:
- Direct communication with our product management team regarding your product idea.
- Notifications whenever new information regarding your idea becomes available.
- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.
- Allow you to shape the future of our products by requesting new controls and products altogether.
- You and other developers can discuss existing product ideas with members of our Product Management team.
Steps to create your idea:
1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
3. Add your product idea and be sure to be specific and provide as much detail as possible.
• Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
• Include a link to this thread in your idea so product management will be able to look back at this case.
The Product Idea site puts you in the driver’s seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Best regards,Martin PavlovInfragistics, Inc.
I would like to know is there any feature to fix some columns at right side and some at left side in a grid, or fix a column at particular position(after or before particular column)
Ex: A,B,C,D,E columns
1. i want to fix col B at left side and col D at right side.
2. i want to fix col B after col D or before col A.
Hello Raju A,
I'm afraid that what you're looking for is not available in igGrid. In igGrid at initialization time you can configure at which side (left or right) user can fix columns.
You can achieve you requirement #1 (fixing columns on left and right at the same time) by having 3 grids next to each other. The left and right grid will act as a left/right containers for fixed columns.
For requirement #2 I need more background information in order to give you some suggestions on how to proceed. For example do you want some columns to be moved by the end user? When you want this rule to be applied?
Best regards,
Martin Pavlov
Infragistics, Inc.
