I'm testing out your igGrid control in a .NET MVC application and I'm having a problem with a column template. I'm trying to do something really simple like.
testColumn.Template = "<a href='http://www.google.com'>http://www.google.com</a>"
The problem I'm having though is that although the link works it looks like plain text. Is there a way to just default the column to look like a normal hyperlink?
Hello James,
By design, a link, in its purest form, is just underlined if not visited, if visited links usually become blue. There is nothing specific for igGrid in regards to styling links. In order to style a link CSS have to be used, the same way we are using it for any other elements. All that needs to be done is targeting the <a> element in stylesheet. Some further reference about styling links can be found here and here.
I know how to style links. I'm just surprised I have to take the extra step to style links inside the grid.
The template for igGrid columns is entirely under the developer`s control. The reason is that different user scenarios require different styling and configuration.
Please let me know if you have any additional questions.
OK thanks
