i selected 3 items,then i turn to page 2.
all right.last i turn back to page 1.
i don't want the 3 items still be selected.How can i do?
The behavior which you're experiencing is by design and there is no option which is controlling it.
You can workaround it by attaching to pageIndexChanged event and call igGridSelection clearSelection method.
Here is sample code:
Best regards,
Martin Pavlov
Infragistics, Inc.
Hi,Martin,
Thanks for your code.
But there's another problem appreaed,after I add your code.
I turn back page 1 .OK. All the Selected item cleared.But when I clicked the checkbox in thead for selecting all the checkbox,the problem happened.
Those selected items before pageindex changed were not selected.
Can you solve the problem?
I'm afraid that you hit a bug, which is reproducible in 11.2, but not in 12.1.
The best way for you will be to upgrade to 12.1. If you can't then there is a workaround which you can use:
Here is the code for the pageIndexChanged event:
Hope this helps,
