I have a crazy problem which seems very simple to solve, but after hours spent on it, I think I really need help.
This is my problem : I create a igGrid using a simple HTML table of a few lines (less than 10). I want to define my own width, header, ... When I write code with autoGenerateColumns set to true, the grid appears, but of course without the appearance.
But when I set autoGenerateColumns to false, the grid never appears : i just have an animation which never stops.
This is the code I have in my web page :
<table id="grid"> <thead> <tr> <th> ID </th> <th> Name </th> <th> Number </th> </tr> </thead> <tbody> <tr><td>1</td><td>Adjustable Race</td><td>AR-5381</td></tr> <tr><td>2</td><td>Bearing Ball</td><td>BA-8327</td></tr> <tr><td>3</td><td>BB Ball Bearing</td><td>BE-2349</td></tr> <tr><td>4</td><td>Headset Ball Bearings</td><td>BE-2908</td></tr> <tr><td>316</td><td>Blade</td><td>BL-2036</td></tr> <tr><td>317</td><td>LL Crankarm</td><td>CA-5965</td></tr> <tr><td>318</td><td>ML Crankarm</td><td>CA-6738</td></tr> <tr><td>319</td><td>HL Crankarm</td><td>CA-7457</td></tr> <tr><td>320</td><td>Chainring Bolts</td><td>CB-2903</td></tr> <tr><td>321</td><td>Chainring Nut</td><td>CN-6137</td></tr> </tbody> </table> <script> $(function () { $("#grid").igGrid({ colums: [ {key:'ID', width:'50px', dataType: 'string'}, {key:'Name', width:'250px', dataType: 'string'}, {key:'Number', width:'150px', dataType: 'string'} ], autoGenerateColumns:false, featureChooserIconDisplay:'always' }); }); </script>
Hi ! I found the problem ...
It was just a mistake in my code : I put "colums" instead of "columns" ..
