Hi all,
We are currently using the IgniteUI igDataChart version (13.2.20132.2157)
We can make it work by using the following Javascript dependency files:
Now, we were trying to reduce the size of the files needed by the igDataChart so that we can improve browser download performance.
We used the following link http://help.infragistics.com/Help/Doc/jQuery/2013.2/CLR4.0/html/Deployment_Guide_JavaScript_Files.html#igDataChart
to establish the minimal files needed to use the igDataChart. Unfortunately, we keep getting errors and this is not working.
Could someone send us the minimal set of files needed to make this work?
Otherwise, is there a way to have a smaller infragistics.dv.min.js file?
Any help would be appreciated.
Stephane
This issue was resolve.
The dependencies for the igDataChart are correct in this link http://help.infragistics.com/Help/Doc/jQuery/2013.2/CLR4.0/html/Deployment_Guide_JavaScript_Files.html#igDataChart
Using RequireJs, needed to specify the dependencies between the different igDataChart files.
shim: { ... "igCore": { deps: ["jquery", "modernizr", "jQueryUI"] }, "igUtils": { deps: ["igCore"] }, "igDv": { deps: ["igCore", "igUtils"] }, "igDataSource": { deps: ["igDv"] }, "igWidgets": { deps: ["igDataSource"] }, "igCategory": { deps: ["igDv"] }, "igScatter": { deps: ["igDv"] }, "igChart": { deps: ["igDataSource", "igWidgets", "igCategory", "igScatter"] }
Another option would have been to use our igLoader component to request only the required chart features.
