Is there a way to prevent records from truncating at 50,000? I have data from the last several years in a database, and when it populates the widget I am creating only data from 2012 is available. When I filter it to show a more recent time period no data is available.
Any advice for getting it to show this data?
I should add that I am using the software to merge two tables--I don't have the option to edit the query when I choose a source that has multiple data points.
Hello Caleb,
In order to get some context information on the issue:Does the issue occurs if you create a new dashboard crossing the same data sources?Is the app displaying error messages?Are you using the free version of the app?
Looking forward to hearing from you.Regards
Gonzalo TAssociate Support SpecialistEnterprise MobilityInfragistics, Inc.
I'm writing to you in order to check if you have further questions.
I will keep this case open for another three days while I wait for your response. If at that time you haven't responded, I will close this case as inactive. Please note that closed cases may be reopened within thirty days of closure.
Best regards.
Gonzalo T Associate Support Specialist Enterprise Mobility Infragistics, Inc.
