We have need to expose data by middle-tier, this for obvious security reasons. Our customers do not allow to connect directly to the database.
I'd like to see an example showing how to consume a WCF service, Web Service, etc.
Tommaso
Hello Tommaso,
ReportPlus supports connections and can consume data provided by OData services.
Here you can find a good example of how you can create OData endpoint using ASP.NET Web API http://www.asp.net/web-api/overview/odata-support-in-aspnet-web-api/odata-v4/create-an-odata-v4-endpointThis topic here explains how to create OData service with WCF https://msdn.microsoft.com/en-us/library/cc668796(v=vs.110).aspx
Also here is a link to how to configure OData data source in ReportPlus https://www.infragistics.com/help/reportplus/how-to-configure-data-sources#ODataService
Please let us know if you have more questions or need further assistance.
Best regards,Plamen
I'm writing to you in order to check if you have further questions.
I will keep this case open for another three days while I wait for your response. If at that time you haven't responded, I will close this case as inactive. Please note that closed cases may be reopened within thirty days of closure.
Best regards.
Gonzalo T Associate Support Specialist Enterprise Mobility Infragistics, Inc.
