when changing the Datasource on a SQL Server database (in our case a view) the changes are not visible on ReportPlus. What is the recommended solution for this?
Also I would like to change the caption of the pages pane. How is this possible??
Thanks in advance
Martin
Same problem. Only solution I've come up with is to simply create a new view each time, although don't use the same name as it reverts to the cached view.
have you tried tapping the refresh button? this button appears on the top, at the left of the share button.
Please note that this button is only displayed on the view mode, so you may need to tap Done first.
