Is there a way to change a data source on an existing dashboard in the reportplus app?
To the Infragistics Team,
I am also very interested to know if there is a solution for this.
Regards
Tony
Hi Bob,
To change the data source
When you next check the path inside the widget it should now show the correct path and filename - must save dashboard first.
Note: It's advisable to save a copy of the dashboard beforehand
Thank you for posting at IG Forums!
How to change the Data Source in an existent Dashboard.
1. Go to the Dashboard you want the Data Source to be changed.
2. Tap “Edit”
3. Tap “Dashboard Settings”
4. In “Dashboard Settings” tap “Change Data Sources
5. You’ll see the next screen.
6. Tapping on one will give you the option to change a used Data Source or to add new ones by tapping in the + symbol.
7. If you choose to add a new one the next screen will appear giving you more options to select.
I hope this helps.
Should you have further questions please let me know.
Kind regards,
