Hi. I'm unable to present on the map the points as follows.
After creating the dashboard, selecting the source of data, map, type of geographical location and selecting fields lat and long it either does not show anything on the map or shut down as on an error (it also sent a couple of log reports to infragistics). Can anyone guide me? Regards FC
Felipe,
Yes. ReportPlus provides backwards compatibility with older version dashboards.
Have a nice weekend.
Great! Can you confirm that dashboards designed for 2.0 will be portable for 3.0?
Regards
Hello Felipe,
Thank you for posting at IG forums!
I created a test dashboard with the data you provided me with, and it worked without issues. This was tested in ReportPlus 3.0 (to be released next week).
Once the new app is released, you may use the attached dashboard as reference.
I hope this helps!
