All,
I am using ReportPlus on an iPad Air (iOS 8.2). I am investigating if ReportPlus is suitable for my business. If so, I will take a subscription.
I can make a dashboard using an Excel sheet with multiple worksheets.
However, saving once is no problem, but after every next save my data is lost and I can start over again.
Is this a known problem, or do I need to take a subscription before this is solved?
Thanks in advance,
Marco
Hello Marco,
Thank you for your support request!
Do you mean that the dashboard data is lost the second time you save it?
This shouldn't happen at all.
Where is the spreadsheet located?
Looking forward to hearing from you,
Javier,
I tested with spreadsheets both local and in dropbox, no difference.
It seems to be that saving works fine, but I need to manually refresh everytime I open the dashboard. Some graphs are shown, some not.
I have a screen shot, but including it does not work for some reason. Can I email my screen shot and spreadsheet?
I thought I found the cause of my problem.
I had about 40 rows in the sheet, and row 41 was a calculation using the 40 rows. I created a filter on the row and wanted the dashboard to start up with row 41.
This did not work.
Starting up with every other row worked fine.
After that, I tried to enter the row 41 manually, but still they did not work.
Sheet lay-out:
row 1 : no desc Yes No
row 2 : Total (xx) 60 40
row 3 : detail 1 80 20
row 4 : detail 2 40 60
Marco,
Thank you for your responses.
Would you mind sending me an example spreadsheet and instructions to duplicate your dashboard? I'm sure the developers will like to reproduce this.
As I am not seem to be able to attach files to the post, to which e-mail address can I send the sheet?
