1147
Select All checkbox in the header of UltraGrid
  I am having Ultragrid html markup like following in which i am having two template columns.
on each template column header there is checkbox to enable SELECT ALL option.
 I am calling a javascipt function shown below on onclick event of header checkboxes.
the select all option is not working as in the if condition it is not finding frm.elements[i].name.lastIndexOf("CheckBox2") for all 4 function
please suggest some solution so that the Select all function on both column will work.
Thanks.
function Delete()
        var frm = document.forms[0];
        var flag=false;
        for (i=0;i<frm.elements.length;i++)
            //alert("Delete _ _ _ "+frm.elements[i].name);
           if(frm.elements[i].type == "checkbox"  && frm.elements[i].name.lastIndexOf("CheckBox2")!= -1)
             //alert("Sucess___"+frm.elements[i].name);
             if(frm.elements[i].checked)
                 flag = true;
        if (flag==false)
           alert('Please select at least one item to delete!');
           return false;
        return confirm('Are you sure to delete selected Roles?');
 function SelectAll(flag)
       alert(error);
          //  alert("DeleteSelectAll _ _ _ "+frm.elements[i].name);
           if (frm.elements[i].type == "checkbox" && frm.elements[i].name.lastIndexOf("CheckBox2")!= -1)
               frm.elements[i].checked = flag; // document.getElementById(id).checked;ChkEnable
  function EnableDisable()
        var flag=false;
          if(frm.elements[i].type == "checkbox" && frm.elements[i].name.lastIndexOf("CheckBox1")!= -1)
                 flag = true;
        if (flag==false)
           alert('Please select at least one item to Enable/Disable!');
           return false;
       return confirm('Are you sure to Enable/Disable?');
 function SelectAllEnableDisable(flag)
      alert(error);
           if (frm.elements[i].type == "checkbox" && frm.elements[i].name.lastIndexOf("CheckBox1")!= -1)
                alert('found one record, name is..'+frm.elements[i].name);
<igtbl:UltraWebGrid ID="InfraGrid_Products" runat="server" Browser="Xml" EnableAppStyling="True"  OnInitializeRow="InitializeRow"
                         OnInitializeDataSource="Load_Through_Ajax"  StyleSetName="Office2007Black" Width="100%">
                        <Bands>
                            <igtbl:UltraGridBand>
                             <Columns>
                                 <igtbl:UltraGridColumn BaseColumnName="UserId" Key="UserId" ServerOnly="True">
                                     <Header Caption="UserId">
                                     </Header>
                                 </igtbl:UltraGridColumn>
                                 <igtbl:UltraGridColumn BaseColumnName="LoginId" Key="LoginId" ServerOnly="True">
                                     <Header Caption="LoginId">
                                         <RowLayoutColumnInfo OriginX="1" />
                                     </Header>
                                     <Footer>
                                     </Footer>
 <igtbl:TemplatedColumn AllowUpdate="Yes" Key="ChkED" SortIndicator="Disabled" Type="CheckBox">
                                     <HeaderTemplate>
                                             <input type="checkbox" runat="server" id="ChkEnable" onclick="BLOCKED SCRIPTSelectAllEnableDisable(this.checked);"  />
                                               <asp:LinkButton ID="Lnk_EnableDisable" runat="server" CausesValidation="false" OnClick="EnableDisableRecords"
                                                 onclientclick="BLOCKED SCRIPTreturn EnableDisable();" Text="Enable/Disable" ToolTip="Enable/Disable"></asp:LinkButton>
                                     </HeaderTemplate>
                                     <CellTemplate>
                                          <input type="checkbox" id="CheckBox1" runat="server" name="CheckBox1"   />
                                     </CellTemplate>
                                     <Header Caption="Delete">
                                         <RowLayoutColumnInfo OriginX="8" />
                                     </Header>
                                     <Footer>
                                     </Footer>
                                 </igtbl:TemplatedColumn>
                                   <igtbl:TemplatedColumn AllowUpdate="Yes" Key="Chk" SortIndicator="Disabled" Type="CheckBox">
                                     <HeaderTemplate>
                                             <input type="checkbox" runat="server" id="cbSelectAll" onclick="BLOCKED SCRIPTSelectAll(this.checked);"  />
                                               <asp:LinkButton ID="Lnk_del" runat="server" CausesValidation="false" OnClick="DeleteSelectedRecords"
                                                 onclientclick="BLOCKED SCRIPTreturn Delete();" Text="Delete" ToolTip="Click to Delete"></asp:LinkButton>
                                     </HeaderTemplate>
                                      <CellTemplate>
                                              <input type="checkbox" id="CheckBox2" runat="server" name="CheckBox2"  />
                                     </CellTemplate>
                                         <RowLayoutColumnInfo OriginX="9" />
                                     </Header>
                                     <Footer>
                                     </Footer>
                    </Columns>
                                <RowStyle Wrap="True" />
                                <AddNewRow View="NotSet" Visible="NotSet">
                                </AddNewRow>
                            </igtbl:UltraGridBand>
                        </Bands>
                        <DisplayLayout AllowColSizingDefault="Free" AllowColumnMovingDefault="OnServer"
                             AllowRowNumberingDefault="Continuous" AllowSortingDefault="OnClient" ColWidthDefault="" GridLinesDefault="NotSet" GroupByColumnsHiddenDefault="No"
                            HeaderClickActionDefault="SortSingle" IndentationDefault="20" LoadOnDemand="Xml"
                            Name="ctl06xInfraGridxProducts" RowHeightDefault="20px" RowSizingDefault="Free"
                            SelectTypeCellDefault="Single" SelectTypeColDefault="Single" SelectTypeRowDefault="Extended"
                            Version="3.00" ViewType="OutlookGroupBy" NoDataMessage="No Products Added" NullTextDefault="Not Set" AutoGenerateColumns="False" AllowUpdateDefault="RowTemplateOnly">
                            <FrameStyle Width="100%">
                            </FrameStyle>
                            <RowStyleDefault Font-Names="Verdana" Font-Size="8pt" Wrap="True">
                            </RowStyleDefault>
                            <ActivationObject BorderColor="" BorderWidth="">
                            </ActivationObject>
                            <FixedCellStyleDefault Wrap="True">
                            </FixedCellStyleDefault>
                            <FilterOptionsDefault AllowRowFiltering="OnClient" FilterUIType="FilterRow">
                            </FilterOptionsDefault>
                            <Pager AllowPaging="True" PageSize="12"></Pager>
                        </DisplayLayout>
                  </igtbl:UltraWebGrid>
  • 28464
    Maybe this forum thread where a customer had a similar scenario will help (a complete working solution with source code is provided there as well)
    http://forums.infragistics.com/forums/p/1540/31541.aspx#31541
  • 10
    Add <ClientSideEvents ColumnHeaderClickHandler="UltraWebGrid1_ColumnHeaderClickHandler" /> to the </DisplayLayout> section of the grid.
    give a keyid for the column
    <igtbl:UltraGridColumn HeaderText="Check" Width="50px" AllowUpdate="Yes" Type="CheckBox" Key="chk1" SortIndicator="Disabled"
                                <CellStyle HorizontalAlign="Center">
                                </CellStyle>
                                <Footer>
                                </Footer>
                                <Header  Caption="Check">
                                </Header>
    then hook up the same with javascript
    function UltraWebGrid1_ColumnHeaderClickHandler(gridName, columnId, button) {
                //Add code to handle your event here.
                var myCol = igtbl_getColumnById(columnId);
                if (myCol.Key == "chk1") {
                    var myGrid = igtbl_getGridById(gridName);
                    for (i = 0; i < myGrid.Rows.length; i++) {
                        if (myGrid.Rows.getRow(i).getCellFromKey("chk1").getValue() == "1") {
                            myGrid.Rows.getRow(i).getCellFromKey("chk1").setValue(0);
                        else {
                            myGrid.Rows.getRow(i).getCellFromKey("chk1").setValue(1);
  • 15
    I have a question. I am using the select all. I have a dataset for my data. When I first load all products I can check them.  then I have a search that searches all products. In the selecting search I can search the products and pull a category of products from the items rendered. Now when i check all it still selects the old products and not the products that is viewable.
