If I set the dateseparator to - or anything else than '/', the datechooser shows the / for separator. When going into edit mode, the separator changes to the one specified (in CultureInfo of the control, or the current thread) but comes back to / when leaving the edit mode.
I'm using the version 8.1.20081.2058
I guess you customized properties of CultureInfo. Focus/nofocus string may use different properties of that object. If you set explicit pattern, then ensure that date-separator property (I do not remember exact name) matches with separators in your pattern.
In fact, I'm just setting it to the french CultureInf, which has a - as a separator.
I actually have not find the property to explicitly set the date pattern of the control. If you can help me on that, I would appreciate it.
The "pattern" is defined in the the same object where "separator". If you changed value of separator-property and want to have same separator in pattern, then you should synchronize those 2 properties. Example:
System.Globalization.
