I have a webform that has a horiz websplitter - "WebSplitter1". I have a listbar (type explorer) within the lower splitter pane. when the browser window is resized smaller, the listbar and its content do not get resized smaller - the list and content appear to remain the same size. However, when the browser window is resized larger, the listbar and contents are resized larger as expected. Note that when I replace the "WebSplitter2" with simple text, the listbar and contents resize smaller and larger as expected.
I have spent quite a bit of time stripping my webform page down to demonstrate this behavior. I have provided this code below so that you can just drop it into VS2008. Simply run this page and resize the browser window "smaller" - then "larger". I am using IE7 and IE8.
Q: How can i get the listbar and its content (which is another websplitter) to automatically resize smaller as well as larger when the browser window is resized smaller and larger? Am I missing a setting on the listbar? or the websplitters?
Thanks in advance!
-chris
<%@ Page Language="C#" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><%@ Register Assembly="Infragistics35.WebUI.UltraWebListbar.v8.3, Version=8.3.20083.1009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.UltraWebListbar" TagPrefix="iglbar" %><%@ Register Assembly="Infragistics35.Web.v8.3, Version=8.3.20083.1009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.LayoutControls" TagPrefix="ig" %><%@ Register Assembly="AjaxControlToolkit" Namespace="AjaxControlToolkit" TagPrefix="cc1" %>
<script runat="server">
</script>
<html xmlns="http://www.w3.org/1999/xhtml"><head runat="server"> <title></title></head><body> <form id="form1" runat="server"> <div> <asp:ScriptManager ID="ScriptManager1" runat="server" EnablePageMethods="true"> <Services> <asp:ServiceReference Path="~/AutoComplete.asmx" /> </Services> </asp:ScriptManager> <ig:WebSplitter ID="WebSplitter1" runat="server" Height="100%" Width="100%" Orientation="Horizontal" DynamicResize="true" ResizeWithBrowser="true"> <Panes> <ig:SplitterPane BorderStyle="None" BorderWidth="0px" ScrollBars="Hidden"> <Template> top pane </Template> </ig:SplitterPane> <ig:SplitterPane BorderStyle="None" BorderWidth="0px" ScrollBars="Hidden"> <Template> <iglbar:UltraWebListbar ID="UltraWebListbar1" runat="server" Width="100%" Height="100%" BarWidth="100%" ViewType="ExplorerBar"> <Groups> <iglbar:Group Text="Group with nested splitter not resizing smaller"> <Template> <ig:WebSplitter ID="WebSplitter2" runat="server" Height="200px" Width="100%" DynamicResize="true" ResizeWithBrowser="true"> <Panes> <ig:SplitterPane BorderStyle="None" BorderWidth="0px" ScrollBars="Hidden"> <Template> left pane </Template> </ig:SplitterPane> <ig:SplitterPane BorderStyle="None" BorderWidth="0px" ScrollBars="Hidden"> <Template> right pane </Template> </ig:SplitterPane> </Panes> </ig:WebSplitter> </Template> </iglbar:Group> </Groups> </iglbar:UltraWebListbar> </Template> </ig:SplitterPane> </Panes> </ig:WebSplitter> </div> </form></body></html>
Iam having the same problem. Please Help.
I have the same problem too. And if try to use Height 100% for listbar it gives an error in BLOCKED SCRIPT
percent--;
If I try to resize the listbar from javascript like:
lst.style.height = document.documentElement.clientHeight - 100;
It put some extra space on top of Items inside all groups
Any suggestion?
