Hi I am working on a ASP.NET 1.1 application using UltraWebGrid 6.1.
I am setting AllowDefault Sorting property to OnClient.
I want to disable sorting of the Grid in some scenarios.
How to disable the Sorting of the Ultraweb grid in Client script?
thanksAshok
Hello Ashok,
There is what we call client-side events documented here:
http://help.infragistics.com/Help/NetAdvantage/NET/2008.3/CLR3.5/html/WebGrid_Client_Side_Events_CSOM.html
and there you can find the
Fired before a column has been sorted on the client.
gridName
String. The name of the Grid which is firing this event.
columnId
String. The id of the column that is being sorted.
Returning "true" from the event handler will cancel the event.
