I have a HTML table in which I have a webDateChooser, and using a css class I am hidding whole HTML table.
My css contains visibility : hidden field. But every thing is getted hidden except the WebDateChooser control.
Why this is happening?
One more thing about this , if I see this using IE8 it hides the webdatechooser but if I go with compatible mode of IE8 it shows the webdatechooser control.
This page is basically tested with IE7 , and was working fine before, i.e. sucessfully hiding the webdatechoser.
but now , not works with compatibility mode.
Got a temporary solution, as I am setting this css using javascipt; I have hidded the webdatechoose explicitly there.
var
oDtChooser1 = igdrp_getComboById('Dt_FixRenew');
oDtChooser1.setVisible(False);
Thanks.
