I am trying to use the ultrawebmenu with a WebHierarchialDataSource in this case 2 SqlDataSource objects (Parent-Child) Has anyone attempted this and if so could they provide an example? The type of Menu I want is the drill down version.
You can use the property DataSourceID="WebHierarchicalDataSource1" of web menu to bind to WebHierarchicalDataSource also you have to set the property TextField of ignav:ItemBinding tag and set column that you will show in menu. For data source I use Northwind DB with employee -> orders tables relation.
Please take a look at the sample code below:<ignav:UltraWebMenu ID="UltraWebMenu1" runat="server" JavaScriptFilename="" WebMenuTarget="VerticalMenu" WebMenuStyle="DrillDown" JavaScriptFileNameCommon="" DataSourceID="WebHierarchicalDataSource1" TargetFrame="" TargetUrl=""> <IslandStyle BackColor="LightGray" BorderStyle="Outset" BorderWidth="1px" Cursor="Default"> </IslandStyle> <HoverItemStyle BackColor="DarkBlue" Cursor="Default" ForeColor="White"> </HoverItemStyle> <Images> <XPSpacerImage Width="0px" /> <SubMenuImage Url="ig_menuTri.gif" /> </Images> <ItemStyle Cursor="Default" /> <DataBindings> <ignav:ItemBinding DataMember="SqlDataSource1_DefaultView" TextField="City" /> <ignav:ItemBinding DataMember="SqlDataSource2_DefaultView" TextField="ShipCity" /> </DataBindings> <DisabledStyle Font-Names="MS Sans Serif" Font-Size="8pt" ForeColor="Gray"> </DisabledStyle> <Levels> <ignav:Level Index="0" /> </Levels>
Hope this helps.
