25
Gird Seleted Items Values
Hi
I working on UltraWebGird
My Requirement is I can select Multipule cells (that contains 'Int' Values) on the grid
I need the all the selected values to collect in variable to sum(Addition) ,
And I have to display the same in TooTip.
I am unable to get the selected cell values
Plz help me
Thanks in Advance
My code is like this
@ Page Language="C#" AutoEventWireup="true" CodeBehind="Default.aspx.cs" Inherits="GridToolTipTry._Default"
@ Register assembly="Infragistics35.Web.v8.3, Version=8.3.20083.1009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.GridControls" tagprefix="ig"
DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
html xmlns="http://www.w3.org/1999/xhtml"
head runat
="server">
<title></title
head
script type
="text/javascript">
function
WebDataDrid1_PageIndexChanging() {
GetGridSelectedRows(
"<%= this.WebDataGrid1.ClientID %>"
function
GetGridSelectedRows(gridname) {
var
grid = $find(gridname);
var
behav = grid.get_behaviors();
var
selection = behav.get_selection();
var
pageindex = behav.get_paging().get_pageIndex();
var
selectedRows = selection.get_selectedRows();
var strSelection = ""
hidSelections = document.getElementById(
"hidSelections"
for
(i = 0; i < selectedRows.get_length(); i++) {
var item = pageindex + "_" + selectedRows.getItem(i).get_index() + "|"
if
(hidSelections.value.indexOf(item) < 0) {
strSelection += item;
hidSelections.value = hidSelections.value + strSelection;
script
body
<form id="form1" runat
="server">
<div
<asp:SqlDataSource ID="GridDataSsource" runat="server"
ConnectionString="<%$ ConnectionStrings:ULTIMATE_NEWConnectionString %>"
SelectCommand
="SELECT ID, ID AS Expr1, ID AS Expr2, ID AS Expr3 FROM Customer">
</asp:SqlDataSource
<br
</div
<asp:HiddenField ID="hidSelections" runat="server"
<ig:WebDataGrid ID="WebDataGrid1" runat="server" AutoGenerateColumns="False"
DataSourceID="GridDataSsource" Height="424px" Width="1063px" DataKeyFields
="ID">
<Behaviors
<ig:Selection CellSelectType
="Multiple">
</ig:Selection
<ig:EditingCore AutoCRUD
="False">
</ig:EditingCore
<ig:RowSelectors
</ig:RowSelectors
<ig:Paging
PagingClientEvents
PageIndexChanging
="WebDataDrid1_PageIndexChanging"
</ig:Paging
<ig:Activation
</ig:Activation
</Behaviors
<Columns
<ig:BoundDataField DataFieldName="ID" Key
="ID">
<Header Text="ID"
</ig:BoundDataField
<ig:BoundDataField DataFieldName="Expr1" Key
="Expr1">
<Header Text="Expr1"
</ig:BoundDataField
<ig:BoundDataField DataFieldName="Expr2" Key
="Expr2">
<Header Text="Expr2"
</ig:BoundDataField
<ig:BoundDataField DataFieldName="Expr3" Key
="Expr3">
<Header Text="Expr3"
</ig:BoundDataField
</Columns
</ig:WebDataGrid
<asp:Label ID="Label1" runat="server"
style="z-index: 1; left: 47px; top: 660px; position: absolute; height: 44px; width: 373px"
Text="Label"></asp:Label
<asp:Button ID="Button1" runat="server" onclick="Button1_Click"
style="z-index: 1; left: 10px; top: 583px; position: absolute; height: 73px; width: 211px"
Text="Button"
</form
body
html
  • 28464
    You can enumerate all cells in the grid with javascript and use the CSOM (client-side object model) function getValue to obtain the value from it. A cell can be reached with something similar to the following javascript
    var grid = igtbl_getGridById(gridname);
    var row = grid.getRow(0); // first row in the root band
    var cell = row.getCell(3); // fourth cell in the row
    var cellval = cell.getValue();
    You can get the selected status of a cell on the client side using the getSelected function. More information can be found in the online documented, in the Cell client-side object model docs here:
    http://help.infragistics.com/Help/NetAdvantage/NET/2008.3/CLR2.0/html/WebGrid_cell_Object_CSOM.html
