Hello,I have a Itemsource which have multiple columns. Some of them should be used for filtering and grouping, while the others should be summed up. Example:Col1 Col2 Col3A B 1A C 2E B 1I would like to have a total sum up for Col3, which is, ungrouped 4.If the user choose to group by Col1 the grid would be (unexpanded):Col1 Sum of Col3A 3E 1If have neither found a way to display sum's of columns nor found how I enrich the grouped by view with more information (for example row count in this group). It would also help, if it would be possible to have a total row which supports grouping, which means that if the user expands a group there would be a subtotal row.RegardsManuel
Hi Manuel,
For updating the content displayed in the a GroupByRow, please check ou tthe following help article, as it explains what information is available and how to modify the DataTemplate:
http://help.infragistics.com/Help/NetAdvantage/Silverlight/2009.1/CLR3.5/html/SL_xamWebGrid_Custom_Groupby_Row_Display.html
For the summary Column, that isn't something we currently offer, however you should be able to easily display that information in the GroupByRow via a ValueConverter.
As for displaying a summary row, this is a feature that we're currently looking into.
-SteveZ
Hi Steve,
that does do the job for me. I'm looking forward for the summary row, but at the moment I can fullfill 90% with the GroupByRow DataTemplate :)
Thank you
Manuel
