Good day,I'm currently trying to use UltraWebMenu as a substitute for the standard menus in SharePoint (in SharePoint Designer), but I have a little setback - I cannot hide the root Node from the SiteMap.This is the code I'm using on my MasterPage:<%@ Register Assembly="Infragistics35.WebUI.UltraWebNavigator.v9.2, Version=9.2.20092.1003, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"Namespace="Infragistics.WebUI.UltraWebNavigator" TagPrefix="ignav" %>// The menu<ignav:UltraWebMenu ID="UltraWebMenu2" runat="server" DataSourceID="topSiteMap"><ExpandEffects ShadowColor="LightGray"></ExpandEffects></ignav:UltraWebMenu>//The SiteMap<asp:SiteMapDataSourceShowStartingNode="False"SiteMapProvider="SPNavigationProvider"id="topSiteMap"runat="server"StartingNodeUrl="sid:1002"/>As you can see I'm using ! ShowStartingNode="False" !, but it still doesn't work and the menu starts from the root (not from its children).Any kind of help will be appreciated. Thanks in advance!
