when I enter date as 13,it's converting into 1/3.instead of auto convertion,I wanted to display warning message that date is invalid when user enters wrong date,
kindly do the needful.it's urgent
Thanks in advance
Lalitha
sorry,it won't accept 13.when user enters 21,it 's converted into 2/1
Hi lalithakovvali,
That is intended behavior. For example, if caret at month-field and there user entered value larger than 1, then second key entry will go into second field, because there are only 12 month and any entry after 2 would produce value larger than 12.
