I am using invokeXmlHttpRequest to send a refresh signal to the grid. I like doing this because the grid is part of a number of interrelated objects (grid/toolbar/listbar) and rather than reload the whole page I just want to refresh the grid data.
oGrid.invokeXmlHttpRequest(oGrid.eReqType.Refresh,
However, if the user has applied a filter to the grid, the columnfilter retains its selected filter item, but the grid loses its filtered data set, and reloads the entire set.
What do I need to do to remind the grid that it has been filtered? Do I process the filters somehow during the XmlHTTPRequest event on the server?
Hello abacusdba,
I have found that using the following will persist the filter and the data.
//triger postback (JavaScript)
igtbl_doPostBack('GridID');
or
FormName.submit();
Better Late than never,
Patrick
Can you intercept the Ajax call made by oGrid.invokeXmlHttpRequest(oGrid.eReqType.Refresh,null,"") ?
Like this:
protected void uwg_XmlHTTPRequest(object sender, XmlHTTPRequestEventArgs e) { if (e.Type == XmlHTTPRequestType.Refresh) { ... filter the dataset } }
