I have 3 events for UltraWebMenu...
UltraWebMenu_DataBound, UltraWebMenu_MenuItemBound ,UltraWebMenu _MenuItemClicked
Out of the above three events, _MenuItemClicked does not get fired even after setting the AUTOPOSTBACK mode to TRUE in the designer.
The other two _DataBound and _MenuItemBound do get fired.
Could you lead me to where m i going wrong with this.
Hi criticstage,
It has been a while since your post, however in case you are still in need of assistance I would be glad to help.
I have investigated your case but was unable to replicate your issue.
In order to research this issue further I would need more information such as your version of .NetAdvantage, used browser and specific settings for the UltraWebMenu. I ran my tests using version 11.1 under IE8 and Mozilla 5.
Please contact me if you have any questions.
Petar IvanovDeveloper Support EngineerInfragistics, Inc.https://www.infragistics.com/support
I have the same problem BUT with UltraWebNavigator. The question is than sometimes MenuItemClicked fires and sometimes not, depends on the page... I have compared the pages and they appear to be similar.
I use IE8 with 2010.3.
