Hello All,I am trying to achieve following: <igGrid:TextColumn Key="B" HeaderText="{Binding Z}" CellStyle="{StaticResource SecondColumn}" TextBlockStyle="{StaticResource CellBlock}"HeaderStyle="{StaticResource HeaderStyleCol1}" />Is it possible to bind a field from ItemoSource to Header text of column..? Right now I have binded an element to header text but it is not working (showing key as header). :(How can I achieve this at design time..? Thanks in advance.
Could you provide a little more detail about why you want to bind to a field in the ItemSource? In general, each item in the ItemSource would have its own value for Z and it would be difficult to determine the correct one to apply.
A better approach would be to create a property in your ViewModel and bind to that property.
