I am having an issue converting the datatype for a UltraGridColumn. I am binding the datasource programmatically, and the column contains a phonenumber which is stored in the database as a string (formatted as 5558581942).
The following properties for the relavent column are being set in the "InitializeLayout" event of the UltraWebGrid:
When I try to look at the value for the cell in the "InitializeRow" event for the UltraWebGrid - the column datatype is still showing "System.Int64", but the value that is display is still 5558581942, rather than (555) 858-1942 (It should also noted that the Value property believes that the type it has is an "System.String"). All the following properties and methods return the wrong value : GetText(), Value, Text.
Any suggestions?
Chad
For the phonenumber column, the format you specified results in a string, which cannot be displayed in a column of type Int64. (It works in the Date/Time column because the format you specified is a valid Date/Time format). Try changing the data type to a string for the formatted phone number.
