Is there a way to achieve wrapping the text in the header column ? I am building the grid at run time using unbound columns so nothing is hard coded.
You could use the approach described in this post:
https://www.infragistics.com/community/forums/f/retired-products-and-controls/38557/wrap-column-header
Hope this helps,
That sort of works, it does wrap the text but when I change the width of the column to where no wrapping would be needed, the height of the column doesn't get smaller....
First Load
Resize the column so wrapping is needed....
Then exapnd the column so no wrapping is needed (notice the column height doesnt resize )
You should set grid's HeaderRowHeight property to "Dynamic":
<ig:XamGrid HeaderRowHeight="Dynamic" />
Is there a way to wrap the Item Template text ? It doesn't wrap by default?
