It looks like there is white space around the text displayed in the header and group by rows. Is there a way to remove this space in order to compress the data as much as possible?
I tried to use a style and set the padding, but had no luck. I'm not sure if the problem was with my code or that was the wrong approach to take. I either had a compile error (when target type was set to HeaderCellControl or no obvious change to the display (when target type was set to CellControl).
This is something like I tried:
<Style x:Key="xy" TargetType="ig:CellControl">
<Setter Property="Padding" Value="2,2,2,2" />
<Setter Property="Background" Value="Yellow" />
<Setter Property="Height" Value="100" />
</Style>
<ig:XamGrid Grid.Column="0" HeaderStyle="{StaticResource xy}"> Is this the correct approach? If so, can you see what I have wrong, or if not can you explain how this should be handled?
The TargetType of the style should be HeaderCellControl which is in the primitives namespace:
xmlns:igPrim="http://schemas.infragistics.com/xaml/primitives"
<Style TargetType="igPrim:HeaderCellControl">
<Setter Property="Padding" Value="0"/>
Hope this helps,
-SteveZ
