I am dynamically adding columns and rows to my UltraWebGrid however the Key property and the Tag properties will not persist to the page. This is a problem when i have cell updates and am trying to check the row or cell identity.
UltraGridRow row = new UltraGridRow(true);
row.Key = tenor.Identity.ToString();
row.Tag ="GRRRR";
this.UltraWebGrid1.Rows.Add(row, false, true);
Any ideas?
I have nearly the same problem:
I am also dynamically adding my columns and rows, i bind a list of objects to my Webgrid.Then I do following:
uwgDaten.Rows[i].Cells.FromKey("myColName").Tag = 1;
After a postback, I want to read out this tag:string tagValue = Int32.Parse(uwgDaten.Rows[i].Cells.FromKey("myColName").Tag.ToString());
Then I get a NullPointerException!
Did you find a solution or another way?
