I'm building the grid dynamically
Like that
columns.Add(new TextColumn { Key = string.Format("[{0}]", key), HeaderText = key});
My xaml Looks like:
<ig:XamGrid Name="grid" AutoGenerateColumns="false" ItemsSource="{Binding Path=DataSource}" ActiveItem="{Binding Path= SelectedItem}"> <interactivity:Interaction.Triggers></interactivity:EventTrigger> <interactivity:EventTrigger EventName="Loaded"> <interactivity:InvokeCommandAction Command="{Binding InitColumnsCommand}" CommandParameter="{Binding ElementName=grid, Path=Columns}" /> </interactivity:EventTrigger> <interactivity:EventTrigger EventName="RowExitedEditMode"> <local:InvokeDelegateCommandAction Command="{Binding SaveCommand}" CommandParameter="{Binding RelativeSource={RelativeSource Self}, Path=InvokeParameter}" /> </interactivity:EventTrigger> </interactivity:Interaction.Triggers> <ig:XamGrid.EditingSettings> <ig:EditingSettings AllowEditing="Row" IsEnterKeyEditingEnabled="True" /> </ig:XamGrid.EditingSettings> </ig:XamGrid>
What I need is Column for numeric value between the range of {0-100}.
How can I achive that?
Thanks a lot.
Hello Liat,
Thank you for your post. I have been looking into it and I can suggest you see this forum threads:
https://www.infragistics.com/community/forums/f/retired-products-and-controls/66509/validation-in-xamgrid
and
https://www.infragistics.com/community/forums/f/retired-products-and-controls/55408/xamgrid-cell-s-data-validation
where it is discussed how to validate the data in the XamGrid’s Cells. Please let me know if this helps you or you have further questions on this matter.
