I have a problem with filtering dates in the xamGrid. I am manually creating the columns as TextColumns and they appear fine in the grid with the format string that I have specified. When bringing up the filter menu it correctly displays the distinct list of dates in the list box but it does not honor my setting of column.FilterColumnSettings.FilterMenuFormatString.
When I select a single date in the filter list which I know has more than 1 row in the grid and click OK the grid is filtered down to a single row. I can't figure out why the grid isn't filtering properly because it can find one row with the date but why skip the rest?
I have attached an image which better illustrates my issue.
Anyone from Infragistics have any idea about this? Should I submit a support request?
Thank you for your post. I have been looking into it and I created a sample project for you following your scenario and everything seems to work ok on my side. If the sample doesn’t satisfies all your needs feel free to modify it, so it reproduces your behavior and send it back to me for further investigation.
Hi Stefan,
Thanks, I appreciate the response and follow up very much!
Your example worked fine but I can't figure out why my app is behaving differently. It is hard to strip out just the grid to provide a sample app but I am going to first try upgrading to a newer version of Infragistics to see if that resolves the issue.
Boyd
Hello Boyd,
I am looking forward to hear from you.
