How to change pivotGrid resource string (for exactly error message)?
For example, when we drag and drop fields from the field selector into the xamPivotGrid (columns or item collection) and the field already exists occurs an error (like, "Item is already added to the collection"). I would like to know if there is a way to change the locale of this error message for another localization/language?
Hello Carlos,
Thank you for your post. I have been looking into it and I can suggest you customize the Resource strings for the XamPivotGrid. Here there is a step by step guidance showing how to do so:
http://help.infragistics.com/Help/Doc/Silverlight/2014.1/CLR4.0/html/Developers_Guide_Customizing_Resource_Strings.html
I also created a sample project for you where I localize the string you wanted. It is used in the InfragisticsSL5.Olap assembly. Please let me know if this helps you or you have further questions on this matter.
Hi Stefan,
Thank you for the quick response and for the sample application. It solved my problem.
Sincerely,
Carlos
Thanks again.
