I'm plotting a lot of time data that may have gaps in. Previously, these gaps would have been connected together to form a continuous line. Our customer desires these to be actual gaps where the data is missing. The graphed data is averaged over minutes so I've merged the data with a list of nulled values, so that where there's a gap it appears as a double? null. (Previously tried double.NAN)
When I perform the merging function using 0 instead of null I get the graph I'm expecting, with it dropping down to zero where there isn't data.
However, when I try to get gaps by using null values the graph is just blank.
Here's the data object I'm graphing:
public class SensorValue { public DateTime MeasureTime { get; set; } public double? Value { get; set; } }
and I've configured it like this:
//Set Data series.DataContext = sensor; series.ValueMemberPath = "Value"; var itemSorceBinding = new Binding("Data.SensorValues"); series.SetBinding(Infragistics.Controls.Charts.Series.ItemsSourceProperty, itemSorceBinding);
Any idea why the graph is just showing no data?
I used double.NaN and get exactly what I want. The reason this wasn't working when I originally tried it (before using null) was because I was using a Spline Series I believe. I changed it to line. LineSeries doesn't seem to like null values but works fine with NaN.
