If you Export to Excel and one of the Visualizations has no data you receive a 500 Internal Server Error and the export aborts, see attached.
There is a work around if you untick the empty visualization on the Export Dashboard window then it will export the other visualizations.
However exporting to Image / PDF & Power Point work correctly even with the empty visualization.
