I had to enter the captured data grid data to local excel sheet...
how can i do that??
i had to run the application for infinite time, so i cannot write it to datapool while running the application..
can i add the records into the datapool while running the scrip???
Rekha.
Hi Rekha
you should be able to use the following to load and save Excel sheet into the DP:
Datapool.DatapoolUtilities.LoadCSV(...) Datapool.DatapoolUtilities.StoreCSV(...) Please mark this replay as answer if this works for you so others can use the same approach Regards, Ammar
Ammar
