I'm working with TestAdvantage 2008 Volume 3 and QTP 9.2. What I need to do is select the left most portion of a node, currently all select does is click the middle. With non infragistics trees you can specify a button to click and an offset but those options don't appear to exist within TestAdvantage. The reason I need to click to the left is due to a button (UIElement) appearing to perform an action on that node.
Michael,
You may be able to use an approach similar to the one that I posted here though rather than accessing the UIElement through the ActiveCell you could access it through the ActiveNode of the tree:
https://www.infragistics.com/community/forums/f/test-automation-for-micro-focus-uft-windows-forms/55836/treeview-has-a-button-that-i-need-to-click-on-in-qtp/287682#287682
Let me know if you have any questions with this matter.
I have the same issue. I need to click on a control at the left portion of the node in the tree, but I cannot figure out how to access that UIElement to click it.
