90
received unhandled exception error in microsoft .net framework when playing back testscript....
Hi, I have received an unhandled exception error a couple of times when playing back testscripts. It looks like it could be an error coming from the application itself, but in the error text there is numerous references to testadvantage. so I am a little confused as to where the error is coming from....I am hoping one of you might have seen this before and might be able to offer some ideas as to why this is happening?
the error occurs when opening a dialog from a menu.
fyi we are running the trial version of testsadvantage ats the moment so I am not sure if this might be the issue as there is a reference to a license in the error text.
thanks, james
below is the full error text....
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at Infragistics.Win.UIElement.DrawChildElements(UIElementDrawParams& drawParams)
   at Infragistics.Win.UIElement.DrawElement(UIElementDrawParams& defaultDrawParams)
   at Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
   at Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3615 (GDR.050727-3600)
    CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Cenovus.PARS.UI.Publish
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Cenovus.PARS.UI.Publish.exe
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Cenovus.PARS.UI
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Cenovus.PARS.UI.DLL
Cenovus.PARS.Service.Client
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Cenovus.PARS.Service.Client.DLL
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Cenovus.PARS.Util
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Cenovus.PARS.Util.DLL
Infragistics2.Win.v10.2
    Assembly Version: 10.2.20102.1004
    Win32 Version: 10.2.20102.1004
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Win.v10.2.DLL
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
log4net
    Assembly Version: 1.2.10.0
    Win32 Version: 1.2.10.0
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/log4net.DLL
Infragistics2.Shared.v10.2
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Shared.v10.2.DLL
System.ServiceModel
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.4506.2152 (SP.030729-0100)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll
SMDiagnostics
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/SMDiagnostics/3.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.Runtime.Serialization
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Web
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.WorkflowServices
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.594.1152
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.WorkflowServices/3.5.0.0__31bf3856ad364e35/System.WorkflowServices.dll
System.ServiceModel.Web
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.ServiceModel.Web/3.5.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
System.IdentityModel
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.IdentityModel/3.0.0.0__b77a5c561934e089/System.IdentityModel.dll
Infragistics2.Win.UltraWinToolbars.v10.2
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Win.UltraWinToolbars.v10.2.DLL
Infragistics2.Win.UltraWinDock.v10.2
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Win.UltraWinDock.v10.2.DLL
Accessibility
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
ybhfmqsm
Mercury.QTP.Agent
    Assembly Version: 8.0.137.0
    Win32 Version: 10.0.408.0
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Mercury.QTP.Agent/8.0.137.0__7d38df5e43b1c39a/Mercury.QTP.Agent.dll
MngUtils
    Assembly Version: 8.0.130.0
    Win32 Version: 8.0.130.0
    CodeBase: file:///C:/WINDOWS/assembly/GAC/MngUtils/8.0.130.0__7d38df5e43b1c39a/MngUtils.dll
CustomBridge
    Assembly Version: 8.0.70.0
    Win32 Version: 10.0.401.0
    CodeBase: file:///c:/program%20files/hp/quicktest%20professional/bin/custombridge.dll
Mercury.QTP.CustomServer
    Assembly Version: 6.5.133.0
    Win32 Version: 6.5.133.0
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Mercury.QTP.CustomServer/6.5.133.0__7d38df5e43b1c39a/Mercury.QTP.CustomServer.dll
Remoting
    Win32 Version: 8.0.70.0
    CodeBase: file:///c:/program%20files/hp/quicktest%20professional/bin/remoting.dll
System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Infragistics2.QTPServer.WinToolbarsManager.v10.2
    Assembly Version: 10.2.20102.1007
    Win32 Version: 10.2.20102.1007
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202010.2/Bin/Infragistics2.QTPServer.WinToolbarsManager.v10.2.dll
Infragistics2.QTPServer.Win.v10.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202010.2/Bin/Infragistics2.QTPServer.Win.v10.2.DLL
Infragistics2.QTPServer.Shared.v10.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202010.2/Bin/Infragistics2.QTPServer.Shared.v10.2.DLL
Interop.NETDISPATCHSERVERLib
    CodeBase: file:///c:/program%20files/hp/quicktest%20professional/bin/Interop.NETDISPATCHSERVERLib.DLL
Infragistics.License
    Assembly Version: 1.0.5005.10
    Win32 Version: 1.0.5005.10
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Infragistics.License/1.0.5005.10__7dd5c3163f2cd0cb/Infragistics.License.dll
Infragistics2.Win.Misc.v10.2
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Win.Misc.v10.2.DLL
Infragistics2.Win.UltraWinEditors.v10.2
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Win.UltraWinEditors.v10.2.DLL
Infragistics2.Win.UltraWinListView.v10.2
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Win.UltraWinListView.v10.2.DLL
Infragistics2.QTPServer.WinMisc.v10.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202010.2/Bin/Infragistics2.QTPServer.WinMisc.v10.2.dll
Infragistics2.Win.UltraWinGrid.v10.2
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Win.UltraWinGrid.v10.2.DLL
Infragistics2.Win.UltraWinGrid.ExcelExport.v10.2
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Win.UltraWinGrid.ExcelExport.v10.2.DLL
Infragistics2.Excel.v10.2
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Excel.v10.2.DLL
System.Data
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Infragistics2.Win.UltraWinSchedule.v10.2
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Win.UltraWinSchedule.v10.2.DLL
Infragistics2.Win.UltraWinTabControl.v10.2
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Win.UltraWinTabControl.v10.2.DLL
Infragistics2.Win.UltraWinTree.v10.2
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Win.UltraWinTree.v10.2.DLL
System.Core
    Win32 Version: 3.5.30729.1 built by: SP
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
Infragistics2.QTPServer.WinEditors.v10.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202010.2/Bin/Infragistics2.QTPServer.WinEditors.v10.2.dll
Infragistics2.QTPServer.WinSchedule.v10.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202010.2/Bin/Infragistics2.QTPServer.WinSchedule.v10.2.dll
Infragistics2.QTPServer.WinTree.v10.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202010.2/Bin/Infragistics2.QTPServer.WinTree.v10.2.dll
Infragistics2.Win.UltraWinDataSource.v10.2
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Win.UltraWinDataSource.v10.2.DLL
Infragistics2.QTPServer.WinGrid.v10.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202010.2/Bin/Infragistics2.QTPServer.WinGrid.v10.2.dll
Infragistics2.QTPServer.WinDockManager.v10.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202010.2/Bin/Infragistics2.QTPServer.WinDockManager.v10.2.dll
System.Runtime.Serialization.Formatters.Soap
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/2.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll
System.Transactions
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
Infragistics2.Win.UltraWinStatusBar.v10.2
    CodeBase: file:///C:/Documents%20and%20Settings/janders2/Local%20Settings/Apps/2.0/GTJZEYLN.RM7/QEDJLPTW.QH6/ceno..tion_19d603975fe50aa0_0001.0000_657a874ea7c4a0ce/Infragistics2.Win.UltraWinStatusBar.v10.2.DLL
DNHookUtils
    Assembly Version: 10.0.249.0
    Win32 Version: 10.0.249.0
    CodeBase: file:///c:/program%20files/hp/quicktest%20professional/bin/dnhookutils.dll
Infragistics2.QTPServer.WinTabControl.v10.2
    CodeBase: file:///C:/Program%20Files/Infragistics/TestAdvantage%20for%20Windows%20Forms%20(HP)%202010.2/Bin/Infragistics2.QTPServer.WinTabControl.v10.2.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
  • 7695
    Hi James,
         While TestAdvantage is mentioned, it is in the loaded assemblies, which if you are replaying a script using TestAdvantage they would be loaded, but they are not listed in the stack trace at all, which makes me believe that they are not involved. The exception is listed in drawing elements, which almost makes me think that this is a threading issue. My thought is a control on the UI thread is either directly or indirectly being modified on a background thread. This can happen if the datasource that a control is bound to is modified on a background thread without having the changes marshaled back to the UI thread in which it lies.
