HI,
1) Iam using Test AdvantageInfragistics 6.3
I am unable to select a item in List Box which is under SwfTreeView.
QTP is not recognizing ListBox.
2) I am not able set the value in Edit Box which is under SwfToolBar but i can able to find the edit box in Swf Tool Bar(Please find the below mentioned code)
I am not able Select the Item from ListBox which is under SwfToolBar
The above mentioned EditBox and ListBox are under one SwfToolbar
Set toolbarObj=SwfWindow("TASER : UAT - Exceptions").SwfToolbar("_panelBlotter_Toolbars_Dock_Ar").Object.ToolbarsManager.Tools
Set toolbarObj=SwfWindow("UAT").SwfToolbar("_panelBlotter_Toolbars").Object.ToolbarsManager.Tools
For x = 0 to toolbarObj.count - 1 If "SearchText" = toolbarObj.GetItem(x).Key Then Set GetToolFromToolbar = toolbarObj.GetItem(x) msgbox GetToolFromToolbar GetToolFromToolbar.Set "Kiran" ( It is throughing error in this line as "Object does not support this property or method)
bToolFound = true msgbox bToolFound Exit for End If Next
Can you please help on this issue.
Thanks & Regards,
Kiran L
It is recommended to use the recorded actions to access it, but if I follow your logic correctly you should be able to use:
GetToolFromToolbar.Text = "Kiran"
