I get the following error msg when QTP tries to click Ok button on a pop-up
Could not load file or assembly 'Infragistics2.Win.v11.1, Version=11.1.20111.9000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.
Line (24): "SwfWindow("Olf.Desktop.Controls.AlertWindow:Op").SwfButton("OK").Click".
If i go to the object repository the object is highlighted correctly . I am not sure why I am facing this issue .
Under C:\WINDOWS\assembly
Infragistics.License shows version 1.0.5005.10
Can you guys please help me resolve this issue. I have installed the evaluation copy
The most common cause of this issue is using the incorrect version of TestAdvantage. For TestAdvantage to work correctly the version must match the version of NetAdvantage used in the application under test.
To find what version of NetAdvantage is used in your application you can look at the assemblies that are used by the application or you could ask your developers. If you need an older version of TestAdvantage, you can find them on the archived downloads page.
Let me know if you have any questions with this matter.
