I have applied filter on my WebDataGrid by following code
this.wdgTradeModificationLog.Behaviors.Filtering.FilterType = Infragistics.Web.UI.GridControls.FilteringType.RowFilter;
The problem is that when I click on filter icon the highlighted box must open,but when the web page is loaded it works fine and randomly clicking on other column filter's icon sometimes it appears the box and then does not appear and stop appearing then whether I click on any column's filter icon
I am getting this error
I have created and attached a sample trying to reproduce the issue. On my side, everything is working as excepted when clicking on the other columns' filter icon while the filter dropdown is opened.
The sample was tested on Chrome, Firefox and IE11. It uses our latest volume release - 20.1.
Please test it on your side and let me know how it behaves. If this is not an accurate demonstration of what you are trying to achieve please feel free to modify it and send it back to me. Alternatively, if the behavior cannot be replicated please feel free to provide your own sample. Remove any external dependencies and code that is not directly related to the issue, zip your application and attach in in this case.
Having a working sample on my side, which I can debug, is going to be very helpful in finding the root cause of this behavior.
Thank you for your cooperation.
4118.Sample.zip
Please sort my this issue that why I am getting error?
Why infragistics throw this error?
In order to find the root cause of this exception please modify the provided sample so that it replicates the issue you are experiencing and send it back to me for further investigation along with steps to reproduce.
This will help me replicate the behavior and debug on my side so that I can provide you with a solution as soon as possible.
