15
Infragistics - WebDataGrid - Row does not get marked dirty when applying formatting to editable cell
I am using WebDataGrid within Infragistics45.Web.v19.2 Ultimate UI for ASP.NET assembly.
When I apply formatting to an editable cell using the DataFormatString property inside the HTML markup and make a change to that cell during run-time, the row does not get marked as dirty. This prevents the RowUpdating event from firing, and hence the data does not get updated.
Is this an Infragistics bug? Can you suggest an alternate way of applying formatting to an editable cell?
Here is some of the relevant markup and code:
HTML:
<ig:WebDataGrid runat="server" ID="wdg" DataKeyFields="Id" Width="100%" AutoGenerateColumns="false" EnableDataViewState="true">
<Columns>
<igtbl2:BoundDataField Key="Id" DataFieldName="Id">
</igtbl2:BoundDataField>
<igtbl2:BoundDataField Key="Price" DataFieldName="Price" CssClass="EditableCell">
</Columns>
<Behaviors>
<igtbl2:EditingCore BatchUpdating="true">
<Behaviors>
<igtbl2:CellEditing EditModeActions-MouseClick="Single" EditModeActions-EnableF2="true" EditModeActions-EnableOnActive="true" EditModeActions-EnableOnKeyPress="true" Enabled="true" CellEditingClientEvents-EnteringEditMode="wdg_CellEdit">
</igtbl2:CellEditing>
</Behaviors>
</igtbl2:EditingCore>
</Behaviors>
</ig:WebDataGrid>
Javascript:
function wdg_CellEdit(sender, eventArgs) {
var cellToEdit = eventArgs.getCell().get_column().get_key();
if (cellToEdit != "Price") {
eventArgs.set_cancel(true);
  • 15
    Hello Friend,
    It seems that you are facing an issue with the Infragistics WebDataGrid where applying formatting to an editable cell using the DataFormatString property inside the HTML markup is causing problems with the RowUpdating event not firing during runtime. To address this, you might want to consider using a different approach to apply formatting to the editable cell.
    One possible solution is to use a TemplateColumn with an ItemTemplate for the DotNet Support cell you want to format. This way, you have more control over the rendering of the cell content while still allowing for editing. Here's an example of how you can modify your markup to use a TemplateColumn:
    ```html
    <Columns>
    <igtbl2:TemplateDataField Key="Price" >
    <ItemTemplate>
    <asp:Label ID="lblPrice" runat="server" Text='<%# Bind("Price", "{0:C}") %>' CssClass="EditableCell"></asp:Label>
    </ItemTemplate>
    <EditModeTemplate>
    <asp:TextBox ID="txtPrice" runat="server" Text='<%# Bind("Price") %>' CssClass="EditableCell"></asp:TextBox>
    </EditModeTemplate>
    </igtbl2:TemplateDataField>
    </Columns>
    <Behaviors>
    <Behaviors>
    </Behaviors>
    </Behaviors>
    </ig:WebDataGrid>
    In this example, I replaced the BoundDataField for "Price" with a TemplateDataField. The ItemTemplate contains a Label for displaying the formatted value, and the EditModeTemplate contains a TextBox for editing. The `{0:C}` format in the Label's Text property ensures the value is displayed as currency.
    This way, you have more control over the formatting of the cell while still allowing for editing, and it may help resolve the issue you are facing with the RowUpdating event.
  • 1300
    After investigating this further, I determined that Activation should be enabled in order for the RowUpdating event to fire. This could be achieved by adding the Activation tag in the Behaviors of the WebDataGrid:
    <Behaviors>
        <ig:EditingCore EditingClientEvents-RowUpdating="update" BatchUpdating="true">
           <Behaviors>
             <ig:CellEditing CellEditingClientEvents-EnteringEditMode="wdg_CellEdit">
                <EditModeActions EnableOnActive="True" EnableOnKeyPress="True" MouseClick="Single"/>
             </ig:CellEditing>
           </Behaviors>
         </ig:EditingCore>
         <ig:Activation>
         </ig:Activation>
    </Behaviors>
    Setting DataFormatString to the editable cell does not affect the triggering of the event. I have prepared a sample, demonstrating the described behavior, the client side event RowUpdating is fired when a cell is edited and the current/active row is changed. Please test it on your side and let me know if you need any further information regarding this matter.
    Monika Kirkova,
