Hello,I'm working on a project update from infragistic UI for ASP.NET WebForm version 10.2 to 20.1.I have some problems with the WebDataGrids for obtain the same graphics of UltraWebGrid.My Grids should have a fixed size, fixed header, vertical scroll bar and "add new rows" on the last of many rows.Until now I have attempted to use sizeless WebDataGrid placed inside a DIV with vertical scroll bars (for have a similar "addNewRow" graphics).But when using fixed header function ( .igg_Header { position: fixed; } ) in css, I have the following problems:- After loading, the grid header is covered by the first row (it's displayed only after a click edit on a cell)- Once displayed, the header covers the first row of the grid.I've tried to using the JQuery script (as explained here in a old post) to overwrite a padding-top of the first grid <TR>, but the script doesn't seem to change the attribute in html.<script src="../scripts/jquery-3.5.1.min.js" type="text/javascript"></script><script type="text/javascript"> $("tbody.igg_Item > tr:first-child td").css("padding-top", "20px");</script>
The definition of this script is still right?
I use a MasterPage which contains the HEAD tag for many pages containing Grids, where I should load the JQueryScript (* .js) and where I should insert the "header padding correction" scripts?If I have more than one WebDataGrid on the same page with different graphics (es. header hidden), how I can point to the right grid?Could you tell me how to proceed?
Thanks!
Thanks Monika, I still have another question about the WebDataGrids that I was unable to insert because the formu queue is under maintenance...
My project Grids have frequently many Columns with WebCombo inside and each one has a visible "Text" and a hidden "Value" (both string).I would need to get the "Value" set by user, when saving page, by reading the Grid update with a loop on "rows" and "columns" and read a Cells (server side in C # code) to write them in a recordset.The DropDown value obtained, once saved on the recordset, in a new Grid DataBind, should load the DropDown displaying the relative Text.This procedure worked with old UltraWebGrids.CmbValueField = Grid.Rows[Rig].Items[Col].Value.ToString(); (Value sample)CmbTextField = Grid.Rows[Rig].Items[Col].Text; (Text sample)Instead, using the WebDataGrid and setting the Grid Column as "BoundDataField" (string) and adding an editor DropDownEditorProvider I can only obtain by code the displayed Text of the DropDown.By making a different selection on the DropDown and reading the new "Value" server side, I always get the value loaded at the first Grid databind: all user changes are ignored.How can I proceed to get the correct "value"?This is my Grid:<ig:WebDataGrid ID="Grid" runat="server" AutoGenerateColumns="False" EnableDataViewState="True" EnableRelativeLayout="True" BorderWidth="0px" Height="435px" Width="745px"> <Columns> <ig:BoundDataField DataFieldName="KKK" DataType="System.Int32" Hidden="True" HtmlEncode="False" Key="KKK" Width="20px"> <Header Text="KKK" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="X99V" DataType="System.Int32" Hidden="True" HtmlEncode="False" Key="X99V" Width="20px"> <Header Text="X99V" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="KC02" DataType="System.String" HtmlEncode="False" Key="KC02" Width="40px"> <Header Text="KC02" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="C02Y" DataType="System.String" HtmlEncode="False" Key="C02Y" Width="200px"> <Header Text="C02Y" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="C02Z" DataType="System.String" HtmlEncode="False" Key="C02Z" Width="200px"> <Header Text="C02Z" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="WC01" HtmlEncode="True" Key="WC01" Width="140px" DataType="System.String"> <Header Text="WC01" /> </ig:BoundDataField> <ig:UnboundCheckBoxField HeaderChecked="False" Key="Del" HeaderCheckBoxMode="Off" Width="20px" CssClass="igg_CheckBoxAlignCentrer"> </ig:UnboundCheckBoxField> </Columns> <EditorProviders> <ig:TextEditorProvider ID="Grid_TextEditor_KC02"> <EditorControl ID="EditorControl1" runat="server" CssClass="igg_EditCell"> </EditorControl> </ig:TextEditorProvider> <ig:TextEditorProvider ID="Grid_TextEditor_C02Y"> <EditorControl ID="EditorControl2" runat="server" CssClass="igg_EditCell"> </EditorControl> </ig:TextEditorProvider> <ig:TextEditorProvider ID="Grid_TextEditor_C02Z"> <EditorControl ID="EditorControl3" runat="server" CssClass="igg_EditCell"> </EditorControl> </ig:TextEditorProvider> <ig:DropDownProvider ID="Grid_Cmb_WC01" StretchHeight="True" > <EditorControl ID="EditorControl4" runat="server" CssClass="igdd_GTComboInGrid" DropDownOffsetX="3" TextField="Valore" ValueField="Chiave" ClientIDMode="Predictable"> <Button DisabledImageUrl="../../Images/Combo/Style1/btn_comboGrid_disabled.gif" HoverImageUrl="../../Images/Combo/Style1/btn_comboGrid_normal.gif" ImageUrl="../../Images/Combo/Style1/btn_comboGrid_normal.gif" PressedImageUrl="../../Images/Combo/Style1/btn_comboGrid_pressed.gif" /> <DropDownItemBinding TextField="Valore" ValueField="Chiave"></DropDownItemBinding> </EditorControl> </ig:DropDownProvider> </EditorProviders> <Behaviors> <ig:Activation> </ig:Activation> <ig:EditingCore AutoCRUD="False" BatchUpdating="True"> <Behaviors> <ig:CellEditing> <ColumnSettings> <ig:EditingColumnSetting ColumnKey="KC02" EditorID="Grid_TextEditor_KC02" ReadOnly="True" /> <ig:EditingColumnSetting ColumnKey="C02Y" EditorID="Grid_TextEditor_C02Y" /> <ig:EditingColumnSetting ColumnKey="C02Z" EditorID="Grid_TextEditor_C02Z" /> <ig:EditingColumnSetting ColumnKey="WC01" EditorID="Grid_Cmb_WC01" /> </ColumnSettings> <EditModeActions MouseClick="Single" /> </ig:CellEditing> <ig:RowAdding> <ColumnSettings> <ig:RowAddingColumnSetting ColumnKey="KC02" EditorID="Grid_TextEditor_KC02" /> <ig:RowAddingColumnSetting ColumnKey="C02Y" EditorID="Grid_TextEditor_C02Y" /> <ig:RowAddingColumnSetting ColumnKey="C02Z" EditorID="Grid_TextEditor_C02Z" /> <ig:RowAddingColumnSetting ColumnKey="WC01" EditorID="Grid_Cmb_WC01" /> </ColumnSettings> <EditModeActions MouseClick="Single" /> </ig:RowAdding> </Behaviors> </ig:EditingCore> <ig:RowSelectors> </ig:RowSelectors> </Behaviors> </ig:WebDataGrid>Thanks in advance.
