85
Vertical Text on WebDataGrid's Header
Hi everyone,
I'm trying to have vertical text on my WebDataGrid's headers (It only has to work with IE).
So I first created the following entry in my css:
.VertiColumn
th {
writing-mode
: tb-rl;
filter
: fliph() flipV();
Then I added such a template in my webdatagrid:
<Templates>
<cc1:ItemTemplate ID="wdgResultsTemplate1" runat="server" TemplateID="VerticalHeader" >
<asp:Label ID="Label12" runat="server" Text="vertic" CssClass="VertiColumn" ></asp:Label >
</cc1:ItemTemplate>
</Templates>
And finally I specified the TemplateId in the header of one column as shown below:
ig:BoundDataField DataFieldName="REINS_SYSTEM" Key="REINS_SYSTEM" Width="35px">
<Header Text="System" TemplateId="VerticalHeader" />
I got an error message saying that I can't have a label in a template.
It seems that I'm off track, could someone redirect me on the right track. I'm not at ease with the templates and the templates collection in the WebDataGrid ;-(
Thanks in advance ! I'll be reactive to give you more details if you ask ;-)
Thanks again !
Yvan
  • 33839
    Suggested Answer
    Hey Yvan,
    Your problem is in how you define your template.  The actual html or control code needs to be insdie of a <Template> tag in the item template.
                 <Templates>
                     <cc1:ItemTemplate ID="WebDataGrid1Template1" runat="server"
                         TemplateID="Template1">
                         <Template>
                         </Template>
                     </cc2:ItemTemplate>
                 </Templates>
    So once you place your label inside a further <Template> tag, it should work.  The one thing I had to change was your css class definition.  I had to take the 'th' part of it out.  Since you're applying it to a label, it's put on a span, not the th.
    Hope this helps out!
    regards,
    David Young
