My requirement in a grid is 1.To generate some columns dynamically 2.Add three controls[2 drop-down list and one label] in dynamically generated columns 3.To freeze header and some columnsI have done this by using WbDataGrid,but some problems arise.The problems are 1. Takes too much time to load the page on the basis of amount of data. 2 Horizontal Scrolling has jerky movementHow to solve this problem? Whether there exist any other grid instead of webDataGrid to meet my requirements? I tried the same in UltraWebGrid also,but not able to generate a header template dynamically.
Hello niza,
it is recommened to use WebDataGrid. Please refer to this link: Adding or Removing a column http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=WebDataGrid_Add_or_Remove_a_Column.html
For your third issue "To freeze header and some columns" I think you mean fixed headers, if so please read this forum thread: http://blogs.infragistics.com/forums/p/55243/284444.aspx#
Hope this helps
