oh!
so much tired about WebDataGrig, don't work like Ultra. After databind, column hidden, column sizing etc not response and get error NullException, but data shown to the grid. What’s the solution can u help me?????????????
Mahfuz
Dhaka
Bangladesh
HI Mahfuz,
It is not clear at all as to where or why you are getting an exception. Is it on the server, client? Did it happen during initial page load or on some postback? What version and build number do you have? The best way for us to check out what you're doing would be if you could attach a small running sample here.
regards,David Young
Oh Sorry!
VS2008
Framework version : 3.5
Error generate from server side during initial page load
<ig:TemplateDataField Key="APP" Header-Text="APP">
<ItemTemplate>
<asp:CheckBox ID="APP" runat="server"
Checked='<%#DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "APP") %>'/>
</ItemTemplate>
<Header Text="APP" />
</ig:TemplateDataField>
but '<%#DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "APP") %>'/> not work.
infragistics checkbox setup problem after databind.
