Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
any one can resolve this issue?
I have problem with update each cell multiple time on
EditingClientEvents-RowUpdating = WebDataGrid1_RowUpdated
that's create slow execution of code
WebDataGrid1_RowUpdated function more then one time call on each cell editing for example we edit cell number 4 then WebDataGrid1_RowUpdated call and update it after that we edit cell number 8 then call WebDataGrid1_RowUpdated for cell 4 that are already updated and after that edit cell 8 as it is if we edit other cells all previos cell are edit against that create repetition of updates.
Following are code for BLOCKED SCRIPT
function WebDataGrid1_RowUpdated(sender, e) {
var index = e.get_row().get_index();
if(index == WebDataGrid2_LastRowIndex){
var row=e.get_row();
if(!ValidateRowGrid2(row))
return false;
var fieldID = row.get_cellByColumnKey("fieldID").get_value();
var curCell4 = row.get_cell(0);
if(fieldID == null || fieldID == undefined)
fieldID =0;
var field1=row.get_cellByColumnKey("field1").get_value();
if(field1== ""){field1=="undefined";}
var NewID=CreateDirectRotaKey(fieldID , field1 )
if(fieldID == 0){curCell4.set_value(NewID,NewID);}
Following code for html
<ig:WebDataGrid ID="WebDataGrid1" DataKeyFields="RKId" runat="server" AutoGenerateColumns="False" autocrud="true" DefaultColumnWidth="100px" EnableTheming="false" ExpansionColumnCss="ExpansionColumn" BorderStyle="None" Font-Bold="False" EnableDataViewState="True" >
<AjaxIndicator Enabled="false" />
<ClientEvents KeyUp="keyUp" Initialize="WebDataGrid1_Grid_Initialize"/>
<Columns>
<ig:BoundDataField DataFieldName="fieldID" Key="fieldID">
</ig:BoundDataField>
<ig:BoundDataField DataFieldName="field1" Width="100px" Key=" field1">
<Header Text="field1"/>
</Columns>
<Behaviors>
<ig:Activation Enabled="true" />
<ig:Selection CellClickAction="Cell" CellSelectType="Single" Enabled="True" RowSelectType="Single" ColumnSelectType="Single" SelectionClientEvents-CellSelectionChanged="WebDataGrid1_CellSelectionChanged" />
<ig:Paging PagerAppearance="Bottom" PageSize="10" Enabled="false" />
<ig:RowSelectors Enabled="true" RowNumbering="true" />
<ig:Sorting SortingMode="Single" Enabled="false" />
<ig:ColumnMoving Enabled="false" />
<ig:ColumnResizing Enabled="false" />
<ig:EditingCore AutoCRUD="false" EditingClientEvents-RowUpdating="WebDataGrid1_RowUpdated" >
<ig:CellEditing EditModeActions-EnableF2="True" EditModeActions-MouseClick="Single" EditModeActions-EnableOnActive="false">
<ColumnSettings>
<ig:EditingColumnSetting ColumnKey="RKId" ReadOnly="true" />
</ColumnSettings>
<EditModeActions MouseClick="Single" EnableOnKeyPress="true"></EditModeActions>
</ig:CellEditing>
<ig:RowDeleting Enabled="false" />
</Behaviors>
</ig:EditingCore>
<ig:Filtering Alignment="Top" Visibility="Hidden" Enabled="false" AnimationEnabled="false" />
</ig:WebDataGrid>
Regards
Asim Hashmi
Hello asmiihasmii,
Thank you for contacting Infragistics.
What NetAdvantage version are you using ?
