I'm using infragistics 11.2. I have a webhierarchicaldatagrid with 3 levels.I have a dataset with 3 tables, each one for each level.If the dataset tables have at least one row, everything works just fine. The webhierarchicaldatagrid is loaded with success, for the parent level and also for the bands.
But if I have 0 rows in all tables of the dataset, when I try to assing the dataset to the webhierarchicaldatagrid datasource I get this error:
System.Web.HttpUnhandledException: Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> System.NullReferenceException: Object reference not set to an instance of an object. at Infragistics.Web.UI.GridControls.JsTypeResolver.ResolveTypeId(Type type) at Infragistics.Web.UI.GridControls.GridField.SaveClientProperties() at Infragistics.Web.UI.GridControls.FormattedGridField.SaveClientProperties() at Infragistics.Web.UI.GridControls.BoundDataField.SaveClientProperties() at Infragistics.Web.UI.Framework.ObjectBase.Infragistics.Web.UI.IClientState.SaveClientProperties() at Infragistics.Web.UI.Framework.ObjectBase.SaveObjectClientProperties(IClientState webObject, StringBuilder builder) at Infragistics.Web.UI.Framework.ObjectBase.WriteClientCollections(StringBuilder builder, ArrayList collections) at Infragistics.Web.UI.Framework.ObjectBase.SaveCollectionsStateToViewState() at Infragistics.Web.UI.Framework.RunBot.HandleSaveViewState() at Infragistics.Web.UI.Framework.Data.FlatDataBoundControl.SaveViewState() at Infragistics.Web.UI.GridControls.BaseGrid.SaveViewState() at Infragistics.Web.UI.GridControls.WebDataGrid.SaveViewState() at Infragistics.Web.UI.GridControls.ContainerGrid.SaveViewState() at Infragistics.Web.UI.GridControls.ContainerGrid.System.Web.UI.IStateManager.SaveViewState() at Infragistics.Web.UI.GridControls.WebHierarchicalDataGrid.SaveViewState() at System.Web.UI.Control.SaveViewStateRecursive() at System.Web.UI.Control.SaveViewStateRecursive() at System.Web.UI.Control.SaveViewStateRecursive() at System.Web.UI.Control.SaveViewStateRecursive() at System.Web.UI.Control.SaveViewStateRecursive() at System.Web.UI.Control.SaveViewStateRecursive() at System.Web.UI.Control.SaveViewStateRecursive() at System.Web.UI.Control.SaveViewStateRecursive() at System.Web.UI.Control.SaveViewStateRecursive() at System.Web.UI.Control.SaveViewStateRecursive() at System.Web.UI.Control.SaveViewStateRecursive() at System.Web.UI.Control.SaveViewStateRecursive() at System.Web.UI.Page.SaveAllState() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) --- End of inner exception stack trace --- at System.Web.UI.Page.HandleError(Exception e) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) at System.Web.UI.Page.ProcessRequest() at System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context) at System.Web.UI.Page.ProcessRequest(HttpContext context) at ASP.empresarial_leadform_aspx.ProcessRequest(HttpContext context) at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Can anybody help me?
Thank you
Hi soniaalves,
I have investigated this scenario using version 11.2.20112.2025 but am so far unable to replicate this behavior. Attached is my test sample bound to an empty 3-level DataSet. In order to investigate this further I would need more information about your specific implementation. A sample illustrating the issue would be greatly appreciated.
Please feel free to contact me if you have any questions.
Please do not hesitate to contact me if you are still experiencing any issues.
Thanks for your reply. I'm using the assembly Infragistics35, version 11.2.20112.1019.
I noticed that in your example, you're using Infragistics4.
Is it possible for you to test your example with framework 3.5?
Thank you for your reply.
I have just tested my sample with the 3.5 framework and still the behavior does not manifest itself. If you can provide me with a small sample illustrating the behavior I would be happy to examine this further.
I attached a sample that reproduces this error.
Thank you.
