65
RowSelectionChanging Event issue
Hi guys,
I need some help to achieve my requirement, we have a set of controls (Text boxs, Date pickers & WebDataGrid v11.1), on page load grid will fill with data and select the first row, which will pre-populate the TextBoxs & Date controls from the Selected Row. If user change the data in any of the TextBoxs & Date Controls and try to Select different Row, then prompt the user with Confirm Message.
To achieve this, i written the following code in RowSelectionChanging event and it works perfectly but only issue is that, Message is dispalying "Twice", i need single message, any help is greatly appreciated.
 function ifgWD_CaseInfo_RowSelectionChanging(sender, eventArgs) {
        if (isDirty == 1) {
            var message = "Changes are pending..."
            var answer = confirm(message)
            if (!answer) {
                eventArgs.set_cancel(true);
                return false;
            else {
                return true;
Sunil
