I' m using Infragistics4.Web.v11.2, IIS 7.5, ASP.NET 4.0
I have a WHDG with three levels. I have assigned CellExporting and RowExporting events of WebExcelExporter, but they are not firing.
protected void ExportToExcel() { this.WebExcelExporter.Export(reportGrid); }
It blows at this line with the above exception and the inner exception is Input string was not in a correct format.
Stack trace: at System.ComponentModel.BaseNumberConverter.ConvertFrom(ITypeDescriptorContext context, CultureInfo culture, Object value)
The types contained in the grid are: GUID, decimal, bool, string
I can't figure out what is not in the correct format?
Hi dekkkart,
Could you please provide me with a small isolated sample, demonstrating the issue, in order to be able to investigate it?
Thank you.
I'm just checking if you have been able to resolve your issue.
Hi there, sorry for the wait response. I'll manage to write a samples in a couple of days.
I'm following up to see if you are still experiencing this issue.
