The columns' lines are not aligned on the WebDataGrid. (windows XP;VS.NET 2012;C#,IE 8)
Hello bitsbird,
I noticed that you have opened a support ticket with the same question. I will have a look at the issue and contact you through your case.
I have got the same problem.
Hello uli,
I have created a support ticket on your behalf with ID CAS-109367-X6S3L4. You can find it in the website, by going to Account - Support activity.
Thank you. I will give more detailed information and we'll see.
Would you please post the solution here? Facing the same problem in IE8.
I had not chance to test it so far, but the problem should be solved in the latest service release. (In my case the problem seems to be related with an updatepanel the grid is located in.)
